Salta al contenuto principale
Sony Dream Machine ICF-C717PJ Battery Replacement
Cosa ti serve
  1. Sony Dream Machine ICF-C717PJ Battery Replacement, Battery: passo 1, immagine 1 di 1
    • To start, use a small phillips screwdriver, to remove the screw located on the battery component on the back of the device.
  2. Sony Dream Machine ICF-C717PJ Battery Replacement: passo 2, immagine 1 di 2 Sony Dream Machine ICF-C717PJ Battery Replacement: passo 2, immagine 2 di 2
    • Once you have removed the screw from the battery cover, pull out the cover using your fingers.
  3. Sony Dream Machine ICF-C717PJ Battery Replacement: passo 3, immagine 1 di 1
    • Remove the remaining screws from the back of the clock.
    • Set them aside for reassembly
  4. Sony Dream Machine ICF-C717PJ Battery Replacement: passo 4, immagine 1 di 2 Sony Dream Machine ICF-C717PJ Battery Replacement: passo 4, immagine 2 di 2
    • Remove the back panel of the clock, pry open with screwdriver if necessary.
    • Ensure that the red wires connecting the back panel and the main device are not frayed or damage before proceeding to the next step.
Conclusione
UW Tacoma, Team S1-G3, Liner Summer 2018 Membro di UW Tacoma, Team S1-G3, Liner Summer 2018
UWT-LINER-SU18S1G3
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,963
