Salta al contenuto principale
Sony DSC-RX10M3 Viewfinder Replacement
Cosa ti serve
  1. Sony DSC-RX10M3 Viewfinder Replacement, Back and Right Panel: passo 1, immagine 1 di 1
    • Remove the twelve 0.7mm Phillips #000 screws from the bottom case.
  2. Sony DSC-RX10M3 Viewfinder Replacement: passo 2, immagine 1 di 2 Sony DSC-RX10M3 Viewfinder Replacement: passo 2, immagine 2 di 2
    • Remove the two 0.7mm screws that secure the right side of the camera.
    • Remove the two 0.7mm screws that secure the left side of the camera, near the Wi-Fi logo and charging port.
  3. Sony DSC-RX10M3 Viewfinder Replacement: passo 3, immagine 1 di 2 Sony DSC-RX10M3 Viewfinder Replacement: passo 3, immagine 2 di 2
    • Gently pull off the plastic eye guard.
  4. Sony DSC-RX10M3 Viewfinder Replacement: passo 4, immagine 1 di 2 Sony DSC-RX10M3 Viewfinder Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the four 0.4mm screws located under the rubber eye guard.
    • Use a plastic opening tool to detach the back panel of the camera.
  5. Sony DSC-RX10M3 Viewfinder Replacement: passo 5, immagine 1 di 1
    • This is a tight spot; make sure you use minimal force when removing the cover.
    • Using tweezers, disconnect the ribbon cable connecting the LCD to the circuit board.
  6. Sony DSC-RX10M3 Viewfinder Replacement: passo 6, immagine 1 di 1
    • This step is only needed if you wish to remove the right side panel.
    • Use a plastic openeing tool to gently detach the right panel.
  7. Sony DSC-RX10M3 Viewfinder Replacement, Viewfinder: passo 7, immagine 1 di 1
    • Using a Phillips #000 screwdriver, remove the silver 0.5mm screw.
  8. Sony DSC-RX10M3 Viewfinder Replacement: passo 8, immagine 1 di 1
    • Use tweezers to detach the ribbon cable from the motherboard.
    • Use upward force when removing the ribbon cable.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,039
