Cosa ti serve
Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
Split this step up into multiple steps based on where screws are being removed from or specify how many screws are removed in this step
Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
Remove the marked 2.5 mm screws with the screwdriver
2 different types of screws are removed in this step: specify the types
Move side panel to get access to screws
Remove two screws (black 2.5mm) with PH #0 screwdriver
In the second picture of the side, it is not the upper screw by the USB that needs removing, but the lower one by the SD/battery door
Remove remaining screw which holds the copper casing in the camera
Using the plastic opening tools, carefully pry off the copper casing at the two pictured points.
Remove casing
Place your finger into the battery port and push up on the SD card holder to push it out of its socket.
Warning Take care because at this stage the senor chip will become exposed to contamination. the grey plate is its heatsink.
Un commento
Dear Isaiah De Leon !
I have a Sony RX 100 Mk4, and it is out of order. :(
First just the digital zoom button (up on the camera) didn't work
Later the manual zoom (lens ring moving) didn't work
Now the rest of the marked buttons does not work.
(Sometimes yes, but usually no funcion at all)
The camera was handled care, didn't fall down, no water contact!
Sony service says, no physical problem, they advise the panel to be replaced. (It is about 120€ + 60€ working fee)
Some Sony fan member advised “the little cable just under dial there that connects all the controls has slowly slipped out. “ could be the problem,
Could You please send a picture which cable can it be, or please any other advice.
Thanks!!!
Ádám
berkesi.adam@gmail.com
