Salta al contenuto principale
Sony DSC-RX100MA Back Cover Replacement
Cosa ti serve
  1. Sony DSC-RX100MA Back Cover Replacement, Back Cover: passo 1, immagine 1 di 3 Sony DSC-RX100MA Back Cover Replacement, Back Cover: passo 1, immagine 2 di 3 Sony DSC-RX100MA Back Cover Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove battery by sliding the tab to open the cover
  2. Sony DSC-RX100MA Back Cover Replacement: passo 2, immagine 1 di 3 Sony DSC-RX100MA Back Cover Replacement: passo 2, immagine 2 di 3 Sony DSC-RX100MA Back Cover Replacement: passo 2, immagine 3 di 3
    • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
    • All screws in the camera can be removed with the PH 0 driver head.
  3. Sony DSC-RX100MA Back Cover Replacement: passo 3, immagine 1 di 3 Sony DSC-RX100MA Back Cover Replacement: passo 3, immagine 2 di 3 Sony DSC-RX100MA Back Cover Replacement: passo 3, immagine 3 di 3
    • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
    • Remove the marked 2.5 mm screws with the screwdriver
  4. Sony DSC-RX100MA Back Cover Replacement: passo 4, immagine 1 di 2 Sony DSC-RX100MA Back Cover Replacement: passo 4, immagine 2 di 2
    • Using the plastic opening tools, carefully pry off the bottom plate.
    • Do not pull too hard as you may break the plastic casing.
  5. Sony DSC-RX100MA Back Cover Replacement: passo 5, immagine 1 di 3 Sony DSC-RX100MA Back Cover Replacement: passo 5, immagine 2 di 3 Sony DSC-RX100MA Back Cover Replacement: passo 5, immagine 3 di 3
    • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
    • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
  6. Sony DSC-RX100MA Back Cover Replacement: passo 6, immagine 1 di 2 Sony DSC-RX100MA Back Cover Replacement: passo 6, immagine 2 di 2
    • Remove the back cover
Conclusione
Altre 2 persone hanno completato questa guida.
KC Egger
Membro da: 02/10/17
315 Reputazione
2 Guide realizzate
Cal Poly, Team 21-1, Maness Winter 2017 Membro di Cal Poly, Team 21-1, Maness Winter 2017
CPSU-MANESS-W17S21G1
5 Membri
10 Guide realizzate
1Commento della guida
Hi! Two of the 1mm screws fell out of my camera from behind the display, where can I find new ones? I keep checking amazon and its kits of 750pcs+ and they don't seem like the right 1mm screws. Do you know where I can get some?
Victoria Gallardo - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 68
Tutti i Tempi: 3,888
