Salta al contenuto principale
Sony Cybershot DSC-W830 Motherboard Replacement
Cosa ti serve
  1. Sony Cybershot DSC-W830 Motherboard Replacement, Battery: passo 1, immagine 1 di 2 Sony Cybershot DSC-W830 Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W830 Motherboard Replacement: passo 2, immagine 1 di 1
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: passo 3, immagine 1 di 3 Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: passo 3, immagine 2 di 3 Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: passo 3, immagine 3 di 3
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W830 Motherboard Replacement: passo 4, immagine 1 di 1
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W830 Motherboard Replacement: passo 5, immagine 1 di 2 Sony Cybershot DSC-W830 Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W830 Motherboard Replacement, Lens: passo 6, immagine 1 di 3 Sony Cybershot DSC-W830 Motherboard Replacement, Lens: passo 6, immagine 2 di 3 Sony Cybershot DSC-W830 Motherboard Replacement, Lens: passo 6, immagine 3 di 3
    • Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Once disconnected, use your fingers to lift lens out of the frame.
  7. Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: passo 7, immagine 1 di 3 Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: passo 7, immagine 2 di 3 Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: passo 7, immagine 3 di 3
    • Lift the power button board up off of the daughterboard.
  8. Sony Cybershot DSC-W830 Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove the single Phillips #000 screw.
    • Use your hands to remove the blue daughterboard.
  9. Sony Cybershot DSC-W830 Motherboard Replacement: passo 9, immagine 1 di 2 Sony Cybershot DSC-W830 Motherboard Replacement: passo 9, immagine 2 di 2
    • Flip the camera around.
    • Remove the black and orange ribbon cables.
  10. Sony Cybershot DSC-W830 Motherboard Replacement, Motherboard: passo 10, immagine 1 di 1
    • Remove the two remaining ribbon cables.
    • Pull the motherboard from the camera.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 353
