Salta al contenuto principale
Sony Cybershot DSC-W80 Lens Replacement
Cosa ti serve
  1. Sony Cybershot DSC-W80 Lens Replacement, Battery: passo 1, immagine 1 di 2 Sony Cybershot DSC-W80 Lens Replacement, Battery: passo 1, immagine 2 di 2
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W80 Lens Replacement: passo 2, immagine 1 di 1
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: passo 3, immagine 1 di 3 Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: passo 3, immagine 2 di 3 Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: passo 3, immagine 3 di 3
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W80 Lens Replacement: passo 4, immagine 1 di 1
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W80 Lens Replacement: passo 5, immagine 1 di 2 Sony Cybershot DSC-W80 Lens Replacement: passo 5, immagine 2 di 2
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W80 Lens Replacement, Lens: passo 6, immagine 1 di 3 Sony Cybershot DSC-W80 Lens Replacement, Lens: passo 6, immagine 2 di 3 Sony Cybershot DSC-W80 Lens Replacement, Lens: passo 6, immagine 3 di 3
    • Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Once disconnected, use your fingers to lift lens out of the frame.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 410
