Introduzione
If your camera won't respond when you press the menu button, delete button, or control wheel, use this guide to replace the internal sensory panel.
Cosa ti serve
Make sure the camera is turned off.
Press the ON/OFF button to turn off the camera.
Altre 5 persone hanno completato questa guida.
5 Commenti
I have issues when I turn the wheel to change the settings on manual mode. Would this be the same part?
Also, where can I find it? I tried to have it professionally repair and was told it needed the whole board and that it was not available any more. Thanks!
Sam, where did you find parts?
