Salta al contenuto principale
Sony Cyber-shot DSC-WX80 Lens Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-WX80 Lens Replacement, LCD Screen: passo 1, immagine 1 di 3 Sony Cyber-shot DSC-WX80 Lens Replacement, LCD Screen: passo 1, immagine 2 di 3 Sony Cyber-shot DSC-WX80 Lens Replacement, LCD Screen: passo 1, immagine 3 di 3
    • Begin by removing all six #00 40mm by 10mm black screws holding the outer frame together with the Phillips #00 Precision Screwdriver.
    • Remember to keep track of all screws as they are small and very easy to lose
  2. Sony Cyber-shot DSC-WX80 Lens Replacement: passo 2, immagine 1 di 3 Sony Cyber-shot DSC-WX80 Lens Replacement: passo 2, immagine 2 di 3 Sony Cyber-shot DSC-WX80 Lens Replacement: passo 2, immagine 3 di 3
    • Take note of the small free moving flap near the battery port seen in the first of the three photos. Be sure to store the free moving flap in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Sony Cyber-shot DSC-WX80 Lens Replacement: passo 3, immagine 1 di 3 Sony Cyber-shot DSC-WX80 Lens Replacement: passo 3, immagine 2 di 3 Sony Cyber-shot DSC-WX80 Lens Replacement: passo 3, immagine 3 di 3
    • Remove the #00 screw from the right hand side (from the LCD screen side) which is adjacent to the master control dial. Reference the first image.
    • Use a spudger or plastic opening tools to pry up the LCD screen and free the two metal tangs on the left side. Reference the second image.
    • Lift up two more metal tabs held down by a thin red plastic strap on the right (master control dial) side. Reference the third image.
    • The thin red plastic strap is very fragile.
  4. Sony Cyber-shot DSC-WX80 Lens Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-WX80 Lens Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using a pair of tweezers, remove the blue ribbon from its connection located toward to the top right of the device. Reference the first image.
    • Using a pair of tweezers, remove the gold ribbon from its connection located to the right of the removed blue ribbon. Reference the second image.
    • Your LCD screen is now removed and you can replace it!
  5. Sony Cyber-shot DSC-WX80 Lens Replacement, Lens: passo 5, immagine 1 di 2 Sony Cyber-shot DSC-WX80 Lens Replacement, Lens: passo 5, immagine 2 di 2
    • After the LCD screen has been removed there is a black metal plate that can be pulled off revealing the motherboard and the lens.
  6. Sony Cyber-shot DSC-WX80 Lens Replacement: passo 6, immagine 1 di 2 Sony Cyber-shot DSC-WX80 Lens Replacement: passo 6, immagine 2 di 2
    Compra
    • To separate the motherboard from the lens there are two ribbon cables that need to be pulled out of their ports using tweezers.
    • Now that the Lens has been removed from the motherboard you can replace it!
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,269
