Salta al contenuto principale
Sony Cyber-shot DSC-WX80 LCD Screen Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-WX80 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement, LCD Screen: passo 1, immagine 3 di 3
    • Begin by removing all six #00 40mm by 10mm black screws holding the outer frame together with the Phillips #00 Precision Screwdriver.
    • Remember to keep track of all screws as they are small and very easy to lose
  2. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 2, immagine 1 di 3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 2, immagine 2 di 3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Take note of the small free moving flap near the battery port seen in the first of the three photos. Be sure to store the free moving flap in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 3, immagine 1 di 3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 3, immagine 2 di 3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 3, immagine 3 di 3
    • Remove the #00 screw from the right hand side (from the LCD screen side) which is adjacent to the master control dial. Reference the first image.
    • Use a spudger or plastic opening tools to pry up the LCD screen and free the two metal tangs on the left side. Reference the second image.
    • Lift up two more metal tabs held down by a thin red plastic strap on the right (master control dial) side. Reference the third image.
    • The thin red plastic strap is very fragile.
  4. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using a pair of tweezers, remove the blue ribbon from its connection located toward to the top right of the device. Reference the first image.
    • Using a pair of tweezers, remove the gold ribbon from its connection located to the right of the removed blue ribbon. Reference the second image.
    • Your LCD screen is now removed and you can replace it!
Conclusione
Altre 4 persone hanno completato questa guida.
2 Commenti
Would the wheel be included with the LCD? The wheel on my camera is broken, and I would like to fix/replace it, so should I just order a new LCD screen?
Caleb V. - Replica
The replacement includes just the compatible LDC screen and the connector; the wheel is a separate piece.
The LCD comes naked, meaning that the fancy screen protector with black frame is not provided. It is kind of a sticker which shall be detached from the original LCD and re-attached to the new one. It would have been a good idea to include it within the fix tip.
Jose Luis Martínez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,801
