Salta al contenuto principale
Sony Cyber-shot DSC-WX80 Battery Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: passo 1, immagine 1 di 3 Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: passo 1, immagine 2 di 3 Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Begin by removing all six #00 screws holding the outer chassis together with the Phillips #00 Precision Screwdriver.
    • Remember to keep track of all screws as they are small and very easy to lose
  2. Sony Cyber-shot DSC-WX80 Battery Replacement: passo 2, immagine 1 di 3 Sony Cyber-shot DSC-WX80 Battery Replacement: passo 2, immagine 2 di 3 Sony Cyber-shot DSC-WX80 Battery Replacement: passo 2, immagine 3 di 3
    • Take note of the small free moving flap near the battery port seen in the first of the three photos. Be sure to store the free moving flap in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Sony Cyber-shot DSC-WX80 Battery Replacement: passo 3, immagine 1 di 1
    • Access where the replacement battery will go indicated by the red square in the photo to your left
    • Now insert your new replacement battery
Conclusione
2 Commenti
Why did you not just open the bottom battery door instead of pulling the camera apart?
Kat - Replica
I am also suprised to know that I should dis-assemble to replace battery. It maybe a joke.
Chung-Suh Ku - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 933
