Salta al contenuto principale
Sony Cyber-shot DSC-WX350 Flash Assembly Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: passo 1, immagine 1 di 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: passo 1, immagine 2 di 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: passo 1, immagine 3 di 3
    • Remove 6 black Phillips 4 mm screws using the J00 head screwdriver tip from the sides and bottom of top cover.
  2. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the black Phillips 4 mm screw using the J00 head screwdriver tip from inside the battery inclosure.
  3. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 3, immagine 1 di 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 3, immagine 2 di 2
    • Use the plastic opening tool to take back cover off. Then take out the LCD screen with your hand.
  4. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 4, immagine 1 di 1
    • Now take the control wheel board out with your hand.
  5. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 5, immagine 1 di 1
    • On the left side of the camera, pull the LCD off the back plate.
    • There will be a ZIF connector by the control wheel, release the connector and remove the LCD.
  6. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 6, immagine 1 di 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 6, immagine 2 di 2
    • Remove silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal cover. Once done take the metal cover off with your hands.
  7. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 7, immagine 1 di 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 7, immagine 2 di 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 7, immagine 3 di 3
    • Using your finger open take off the three zifs.
  8. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 8, immagine 1 di 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 8, immagine 2 di 2
    • Use your hand to take out the lens assembly. Then take out the motherboard assembly with your hand.
  9. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 9, immagine 1 di 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 9, immagine 2 di 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 9, immagine 3 di 3
    • Remove the silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal piece and remove the 4mm screws from the metal piece lining the lens assembly hole.
  10. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 10, immagine 1 di 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 10, immagine 2 di 2
    • Grab the top of the camera and take it out. Then grab the flash assembly and slide it out.
Conclusione
Altre 4 persone hanno completato questa guida.
IUPUI, Team S1-G1, Wilson Summer 2017 Membro di IUPUI, Team S1-G1, Wilson Summer 2017
IUPUI-WILSON-SU17S1G1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,690
