Salta al contenuto principale
Sony Cyber-shot DSC-WX220 Flash Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-WX220 Flash Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the gray switch from lock to open position.
  2. Sony Cyber-shot DSC-WX220 Flash Replacement: passo 2, immagine 1 di 2 Sony Cyber-shot DSC-WX220 Flash Replacement: passo 2, immagine 2 di 2
    • Pull down on the blue tab to release the battery.
  3. Sony Cyber-shot DSC-WX220 Flash Replacement, Outer Case: passo 3, immagine 1 di 3 Sony Cyber-shot DSC-WX220 Flash Replacement, Outer Case: passo 3, immagine 2 di 3 Sony Cyber-shot DSC-WX220 Flash Replacement, Outer Case: passo 3, immagine 3 di 3
    • Use a PH00 screwdriver to remove the five 3.5 mm screws.
    • Use a PH00 screwdriver to remove the two 2.5 mm screws.
  4. Sony Cyber-shot DSC-WX220 Flash Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-WX220 Flash Replacement: passo 4, immagine 2 di 2
    • Pry apart the case gently using a plastic opening tool.
  5. Sony Cyber-shot DSC-WX220 Flash Replacement, Flash Assembly: passo 5, immagine 1 di 1
    • Pry back the panel to the right of the screen using a plastic opening tool.
  6. Sony Cyber-shot DSC-WX220 Flash Replacement: passo 6, immagine 1 di 1
    • Working on the left side of the screen, pry the metal panel off from the motherboard housing using a plastic opening tool.
  7. Sony Cyber-shot DSC-WX220 Flash Replacement: passo 7, immagine 1 di 1
    • Pull out the ZIF cable from the motherboard.
    • When removing the ZF cable, pull it straight out to avoid damaging the cable.
  8. Sony Cyber-shot DSC-WX220 Flash Replacement: passo 8, immagine 1 di 1
    • Pull the capacitor out of the shell.
    • Be careful not to shock yourself on the capacitor(metal components on the top)
  9. Sony Cyber-shot DSC-WX220 Flash Replacement: passo 9, immagine 1 di 1
    • Unpin the flash assembly.
  10. Sony Cyber-shot DSC-WX220 Flash Replacement: passo 10, immagine 1 di 1
    • Lift flash component toward you and gently pull the ZIF cable up and away from the camera.
Conclusione
Kate Glazer
Membro da: 03/20/18
621 Reputazione
5 Guide realizzate
IUPUI, Team S6-G3, Baechle Spring 2018 Membro di IUPUI, Team S6-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G3
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 559
