Salta al contenuto principale
Sony Cyber-shot DSC-WX100 Outer Casing Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Battery: passo 1, immagine 1 di 1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: passo 2, immagine 1 di 1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: passo 3, immagine 1 di 3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: passo 3, immagine 2 di 3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: passo 3, immagine 3 di 3
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: passo 4, immagine 2 di 2
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: passo 5, immagine 1 di 2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: passo 5, immagine 2 di 2
    • Use a plastic opening tool to gently release the two indicated tabs.
Conclusione
Altre 2 persone hanno completato questa guida.
Matthew
Membro da: 03/18/15
583 Reputazione
4 Guide realizzate
Un commento
Where I can buy the Outer Casing..¿??
ING CHARLY - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 871
