Cosa ti serve
Remove all of the 1mm screws using a Philips #000 Screwdriver.
Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
Pull up on the lower end of the plate. Lift so the plate is high enough that the marked bump is not holding it in place.
Pull away from the camera at the end of the metal plate with the blue circuits to then remove the plate from the rest of the camera.
