Salta al contenuto principale
Sony Cyber-shot DSC-WX100 Battery Replacement
  1. Sony Cyber-shot DSC-WX100 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Battery Replacement: passo 2, immagine 1 di 1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
Conclusione
Peter Prins
Membro da: 03/19/15
262 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,029
