Salta al contenuto principale
Sony Cyber-shot DSC-W800 Button Board Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: passo 1, immagine 1 di 3 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: passo 1, immagine 2 di 3 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: passo 1, immagine 3 di 3
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Button Board Replacement: passo 2, immagine 1 di 2 Sony Cyber-shot DSC-W800 Button Board Replacement: passo 2, immagine 2 di 2
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Button Board Replacement: passo 3, immagine 1 di 3 Sony Cyber-shot DSC-W800 Button Board Replacement: passo 3, immagine 2 di 3 Sony Cyber-shot DSC-W800 Button Board Replacement: passo 3, immagine 3 di 3
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 17-5, Blackwell Winter 2016 Membro di USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
5 Membri
5 Guide realizzate
4 Commenti
Thanks for this - was spot on and allowed me to easily fix the problem I was experiencing!
jimbradshaw - Replica
follow the step camera button loosen a bit unstuck but camera still stock on language setting and do not budge
Trisha Amable Girlfridayz - Replica
follow the step the button are unstuck but the camera display still stock on language setting
i need a new strip, because old strip was damaged.
moonbhaai@gmail.com
Naveed Shoukat - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 26
Tutti i Tempi: 2,355
