Salta al contenuto principale
Introduzione
This is just a small step after taking the outer case off. This can be done with ease. Be careful with the ribbons though
  1. Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom. Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom. Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Take off the front part of the case with a plastic opening tool. Take off the front part of the case with a plastic opening tool. Take off the front part of the case with a plastic opening tool.
    • Take off the front part of the case with a plastic opening tool.
  3. Pull off the two silver side pieces on the left and right sides. Pull off the two silver side pieces on the left and right sides.
    • Pull off the two silver side pieces on the left and right sides.
  4. Kit di riparazione per Android
    Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
    Acquista ora
    Acquista ora
  5. Remove the main back piece. It should easily lift off. Remove the main back piece. It should easily lift off.
    • Remove the main back piece. It should easily lift off.
  6. Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease. Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease. Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
  7. Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard. Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
    • Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
  8. Once the case is off, hold down the ribbon near the LCD screen that connects the flash to the camera. While doing this, carefully lift the control board that contains the flash until the ribbon is no longer connected. Once the case is off, hold down the ribbon near the LCD screen that connects the flash to the camera. While doing this, carefully lift the control board that contains the flash until the ribbon is no longer connected. Once the case is off, hold down the ribbon near the LCD screen that connects the flash to the camera. While doing this, carefully lift the control board that contains the flash until the ribbon is no longer connected.
    • Once the case is off, hold down the ribbon near the LCD screen that connects the flash to the camera. While doing this, carefully lift the control board that contains the flash until the ribbon is no longer connected.
  9. Once you have removed the piece this is what it will look like.
    • Once you have removed the piece this is what it will look like.
Conclusione
Douglas Howe
Membro da: 08/01/2015
474 Reputazione
4 Guide realizzate
USF Tampa, Team 9-4, Blackwell Winter 2015 Membro di USF Tampa, Team 9-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G4
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 523
