Salta al contenuto principale
Sony Cyber-shot DSC-W570 Case Cover Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-W570 Case Cover Replacement, Case Cover: passo 1, immagine 1 di 1
    • Remove the two Phillips head, 2.93 mm long screws at the bottom of the camera.
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 Case Cover Replacement: passo 2, immagine 1 di 1
    • Turn the camera sideways so the left side is fasning upwards, remove the two Phillips head, 2.93 mm screws.
  3. Sony Cyber-shot DSC-W570 Case Cover Replacement: passo 3, immagine 1 di 1
    • Now turn the device so the opposite side is fasning upwards and remove the last two Phillips head, 2.93 mm screws.
  4. Sony Cyber-shot DSC-W570 Case Cover Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-W570 Case Cover Replacement: passo 4, immagine 2 di 2
    • To remove the front cover, use a plastic opening tool gently pry the top cover.
    • Then gently lift the cover off.
  5. Sony Cyber-shot DSC-W570 Case Cover Replacement: passo 5, immagine 1 di 2 Sony Cyber-shot DSC-W570 Case Cover Replacement: passo 5, immagine 2 di 2
    • To remove the back case cover from the body.
    • First use a plastic opening tool gently pry along the side of the camera.
    • Then slowly and gently lift the cover off.
Conclusione
Zizheng Su
Membro da: 01/21/15
101 Reputazione
1 Guida realizzata
USF Tampa, Team 9-1, Brown Winter 2015 Membro di USF Tampa, Team 9-1, Brown Winter 2015
USFT-BROWN-W15S9G1
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 698
