Salta al contenuto principale
Sony Cyber-shot DSC-W55 Lens Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-W55 Lens Replacement, Battery: passo 1, immagine 1 di 2 Sony Cyber-shot DSC-W55 Lens Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 Lens Replacement: passo 2, immagine 1 di 2 Sony Cyber-shot DSC-W55 Lens Replacement: passo 2, immagine 2 di 2
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Lens Replacement, Back Case: passo 3, immagine 1 di 2 Sony Cyber-shot DSC-W55 Lens Replacement, Back Case: passo 3, immagine 2 di 2
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Lens Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-W55 Lens Replacement: passo 4, immagine 2 di 2
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
  5. Sony Cyber-shot DSC-W55 Lens Replacement: passo 5, immagine 1 di 1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Lens Replacement: passo 6, immagine 1 di 2 Sony Cyber-shot DSC-W55 Lens Replacement: passo 6, immagine 2 di 2
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
    Muchas gracias, muy claro!!
    Ruben - Replica
  7. Sony Cyber-shot DSC-W55 Lens Replacement, Front Case: passo 7, immagine 1 di 1
    • Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
  8. Sony Cyber-shot DSC-W55 Lens Replacement: passo 8, immagine 1 di 3 Sony Cyber-shot DSC-W55 Lens Replacement: passo 8, immagine 2 di 3 Sony Cyber-shot DSC-W55 Lens Replacement: passo 8, immagine 3 di 3
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
  9. Sony Cyber-shot DSC-W55 Lens Replacement, Lens: passo 9, immagine 1 di 2 Sony Cyber-shot DSC-W55 Lens Replacement, Lens: passo 9, immagine 2 di 2
    • Flip the black secure locks off. Tweezers may be necessary.
    • Detach the two orange cables.
  10. Sony Cyber-shot DSC-W55 Lens Replacement: passo 10, immagine 1 di 2 Sony Cyber-shot DSC-W55 Lens Replacement: passo 10, immagine 2 di 2
    • Gently pull the lens container out of the camera.
Conclusione
Altre 15 persone hanno completato questa guida.
kkfong91
Membro da: 10/11/10
344 Reputazione
2 Guide realizzate
Cal Poly, Team 9-20, Regan Fall 2010 Membro di Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
5 Membri
18 Guide realizzate
2 Commenti
Thanks for this guide !
unfortunatly I thinks that my lens is broken (doesn't open anymore, it may have sand inside it)
Do you know where an if I can buy a new lens ?
Erwann Robin - Replica
Thanks for info..
Need a broken lens unit as my lens cable is broken, email me if any one wants to sell a broken lens unit. at barrettoagnelo@yahoo.com
agnelobarretto - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 115
Tutti i Tempi: 22,072
