Salta al contenuto principale
Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Place the Sony Cyber-shot DSC-W510 on the magnetic project mat. This will help keep the small screws organized.
  2. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Unscrew: passo 2, immagine 1 di 2 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Unscrew: passo 2, immagine 2 di 2
    • Using the Phillips #00 screwdriver, unscrew the outside screws from the frame of the camera.
    • There are five screws on the bottom of the camera and two on the side.
    • If the screws are stripped, visit the Removing a Stripped Screw Guide.
  3. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 3, immagine 1 di 2 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 3, immagine 2 di 2
    • Pry open the screen frame using a plastic opening tool.
    • It may be necessary to start by prying at one end of the screen and moving around the edge of the screen frame, until it pops out.
  4. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 4, immagine 2 di 2
    • Using the screw driver, unscrew the one screw on the control panel board.
  5. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 5, immagine 1 di 1
    • Gently unplug the control panel from the motherboard outlet.
  6. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 6, immagine 1 di 2 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 6, immagine 2 di 2
    • Using your hands, pry open the LCD screen from the metal board.
    • Gently unplug the LCD screen from the motherboard.
  7. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Lens Zoom Unit: passo 7, immagine 1 di 2 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Lens Zoom Unit: passo 7, immagine 2 di 2
    • Remove the screws from the metal board using the Phillips #00 screwdriver.
    • Pop apart the metal board using the plastic opening tool.
    • Peel apart the black tape from the flash bulb.
    • Avoid touching the bulb as it will burn or shock if touched.
  8. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 8, immagine 1 di 3 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 8, immagine 2 di 3 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 8, immagine 3 di 3
    • Pry open the remaining covers of the camera using the plastic opening tool.
    • Some parts may fall out during this process.
  9. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 9, immagine 1 di 1
    • Unscrew the one screw from the motherboard.
    • Disconnect the two links from the camera unit to the motherboard.
  10. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 10, immagine 1 di 1
    • Pop out the lens zoom unit from the frame by using either your thumb or an opening tool.
Conclusione
Altre 4 persone hanno completato questa guida.
kyle
Membro da: 02/05/15
424 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,266
