Salta al contenuto principale
Sony Cyber-shot DSC-W5 LCD Screen Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-W5 LCD Screen Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 2, immagine 1 di 2 Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 2, immagine 2 di 2
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 3, immagine 1 di 2 Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  4. Sony Cyber-shot DSC-W5 LCD Screen Replacement, LCD Screen: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-W5 LCD Screen Replacement, LCD Screen: passo 4, immagine 2 di 2
    • Remove the two screws holding the circuit board down.
  5. Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Detach the orange cable from the board.
    • Use a thin object, like a paperclip, to gently pry the cable off the connector.
  6. Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 6, immagine 1 di 2 Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 6, immagine 2 di 2
    • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
    • Slide LCD screen from the two slots.
    • Do not attempt to completely remove the screen, as it is still attached to the camera.
  7. Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 7, immagine 1 di 3 Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 7, immagine 2 di 3 Sony Cyber-shot DSC-W5 LCD Screen Replacement: passo 7, immagine 3 di 3
    • To remove the LCD screen, detach the orange cable from the board.
    • If needed, replace the LCD screen.
Conclusione
Altre 4 persone hanno completato questa guida.
Thomas
Membro da: 04/14/10
133 Reputazione
6 Guide realizzate
Cal Poly, Team 15-50, Garner Spring 2010 Membro di Cal Poly, Team 15-50, Garner Spring 2010
CPSU-GARNER-S10S15G50
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 11,358
