Introduzione
To remove the Lens assembly, you must have background knowledge about disassembling the camera. (See previous guides)
Cosa ti serve
Find the hatch labeled "open" on the left side of the bottom of the camera.
Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
Remove the four 2.5mm Phillips #0 screws.
Gently pull the LCD and its casing away from the motherboard as shown.
Turn the camera so the back is facing you.
Remove the 2.5mm Philips #0 screw at the top of the camera.
Altre 5 persone hanno completato questa guida.
