Introduzione
This guide will teach you how to replace the Sony Cyber-shot DSC-W290's LCD screen.
Cosa ti serve
Find the hatch labeled "open" on the left side of the bottom of the camera.
Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
Remove the four 2.5mm Phillips #0 screws.
Gently pull the LCD and its casing away from the motherboard as shown.
Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
Caution: Do NOT attempt to remove the logic board itself until the LCD is completely off.
Altre 3 persone hanno completato questa guida.
2 Commenti
At Step 13, when re-assembling, insert the large ribbon into the slot using fingers then seat as far in as possible by pushing on each side gently, using tweezers.
