Salta al contenuto principale
Sony Cyber-shot DSC-W290 LCD Assembly Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-W290 LCD Assembly Replacement, Battery: passo 1, immagine 1 di 1
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 2, immagine 1 di 1
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
  3. Sony Cyber-shot DSC-W290 LCD Assembly Replacement, Outer Casing: passo 3, immagine 1 di 2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement, Outer Casing: passo 3, immagine 2 di 2
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
  4. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 4, immagine 1 di 3 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 4, immagine 2 di 3 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 4, immagine 3 di 3
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
  5. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 5, immagine 1 di 3 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 5, immagine 2 di 3 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 5, immagine 3 di 3
    • Turn the camera so the right side faces you.
  6. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 6, immagine 1 di 1
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
  7. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 7, immagine 1 di 2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 7, immagine 2 di 2
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
  8. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 8, immagine 1 di 2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 8, immagine 2 di 2
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
  9. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 9, immagine 1 di 2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 9, immagine 2 di 2
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
  10. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 10, immagine 1 di 2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 10, immagine 2 di 2
    • This is what your camera should look like now that you have removed the casing from all sides.
  11. Sony Cyber-shot DSC-W290 LCD Assembly Replacement, LCD Assembly: passo 11, immagine 1 di 1
    • Gently pull the LCD and its casing away from the motherboard as shown.
    • Be careful not to rip out any ribbon cables.
  12. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 12, immagine 1 di 2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 12, immagine 2 di 2
    • Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
    • Do not use excessive force to remove the wire because this may cause it to tear.
    Caution: Do NOT attempt to remove the logic board itself until the LCD is completely off.
    Sanat Sahasrabudhe - Replica
  13. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 13, immagine 1 di 2 Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 13, immagine 2 di 2
    • Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
  14. Sony Cyber-shot DSC-W290 LCD Assembly Replacement: passo 14, immagine 1 di 1
    • Pull the LCD and its casing away from the rest of the camera.
Conclusione
Altre 3 persone hanno completato questa guida.
Evan Mayer
Membro da: 10/05/10
318 Reputazione
5 Guide realizzate
Cal Poly, Team 7-54, Amido Fall 2010 Membro di Cal Poly, Team 7-54, Amido Fall 2010
CPSU-AMIDO-F10S7G54
4 Membri
16 Guide realizzate
2 Commenti
where can i get a replacement screen but one that isn't that expensive~
jenna - Replica
At Step 13, when re-assembling, insert the large ribbon into the slot using fingers then seat as far in as possible by pushing on each side gently, using tweezers.
Christopher Bell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 16
Tutti i Tempi: 6,598
