Salta al contenuto principale
Sony Cyber-shot DSC-W230 LCD Display Screen Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement, Separating Camera and Display: passo 1, immagine 1 di 2 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement, Separating Camera and Display: passo 1, immagine 2 di 2
    • Align the camera so that the side with "4x Optical Zoom" is facing toward you.
    • Gently twist the bottom corner clockwise until you feel the side panel unlock.
    • Lift off the side panel and set aside.
  2. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: passo 2, immagine 1 di 2 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: passo 2, immagine 2 di 2
    • Rotate the camera 180 degrees to face the side panel with the lanyard loop on it.
    • Gently lift the panel vertically until it lifts off
    • Take care to not lose the small rectangular portion on the bottom of the panel.
  3. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: passo 3, immagine 1 di 3 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: passo 3, immagine 2 di 3 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: passo 3, immagine 3 di 3
    • Position the camera so the bottom is facing up and the display away from the surface.
    • Gently pry the screen portion from the camera portion with your fingers or a plastic prybar.
    • Do not fully separate the two components! the screen is attached by two ribbon cables.
    • Lay the display flat to expose the circuit board and the display control ribbon cables.
  4. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement, LCD Display Screen: passo 4, immagine 1 di 1
    • Using a flat head screw driver gently pry up the tab securing the ribbon cable from the display screen to the camera sensor and battery housing.
    • Remove the ribbon cable connecting LCD display to camera sensor and battery housing
    • Following the same procedure as above, uninstall the ribbon cable connecting the main camera controls to the camera sensor and battery housing
  5. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: passo 5, immagine 1 di 1
    • The LCD display screen is now removed from the camera sensor and battery housing.
    • The main camera controls are now removed from the camera sensor and battery housing.
  6. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: passo 6, immagine 1 di 1
    • Unsnap LCD display screen from its mount by unsnapping it from the display screen using your finger nail.
    • Now the new LCD screen can be installed.
Conclusione
Altre 2 persone hanno completato questa guida.
Clemson, Team 2-3, Benson Spring 2012 Membro di Clemson, Team 2-3, Benson Spring 2012
CLEM-BENSON-S12S2G3
3 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 43
Tutti i Tempi: 3,876
