Salta al contenuto principale
Sony Cyber-shot DSC-W150 Back Casing Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-W150 Back Casing Replacement, Back Casing: passo 1, immagine 1 di 1
    • The screws from the camera are extremely small, so it is a good idea to have a small container to hold all the screws as you remove them.
  2. Sony Cyber-shot DSC-W150 Back Casing Replacement: passo 2, immagine 1 di 1
    • Take your screwdriver and remove the four silver bottom screws of the camera.
    • The picture shows the lens facing away from you and the LCD facing you.
  3. Sony Cyber-shot DSC-W150 Back Casing Replacement: passo 3, immagine 1 di 1
    • On the right side of the camera, remove the two silver screws using the screwdriver.
    • The picture shows the lens facing away from you and the LCD screen facing you.
  4. Sony Cyber-shot DSC-W150 Back Casing Replacement: passo 4, immagine 1 di 1
    • On the left side of the camera, remove the two silver screws using the screwdriver.
  5. Sony Cyber-shot DSC-W150 Back Casing Replacement: passo 5, immagine 1 di 1
    • Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
  6. Sony Cyber-shot DSC-W150 Back Casing Replacement: passo 6, immagine 1 di 1
    • After detaching the back cover, carefully pull it off.
  7. Sony Cyber-shot DSC-W150 Back Casing Replacement: passo 7, immagine 1 di 1
    • The back cover should now be separated from the camera.
Conclusione
Altre 4 persone hanno completato questa guida.
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 5,008
