Salta al contenuto principale
Sony Cyber-shot DSC-TX7 Front Cover Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-TX7 Front Cover Replacement, Battery: passo 1, immagine 1 di 2 Sony Cyber-shot DSC-TX7 Front Cover Replacement, Battery: passo 1, immagine 2 di 2
    • The battery compartment is located on the bottom of camera.
    • Move the slider from the 'lock' position to the 'open' position.
  2. Sony Cyber-shot DSC-TX7 Front Cover Replacement: passo 2, immagine 1 di 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: passo 2, immagine 2 di 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: passo 2, immagine 3 di 3
    • Battery not shown.
    • Pull battery from compartment.
    • Insert newly charged battery into compartment, as shown in diagram (located in compartment).
    • Shut compartment door.
    • Move the slider back to the 'lock' position.
  3. Sony Cyber-shot DSC-TX7 Front Cover Replacement, Front Cover: passo 3, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the 4mm length screws. There are 6 screws total.
  4. Sony Cyber-shot DSC-TX7 Front Cover Replacement: passo 4, immagine 1 di 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: passo 4, immagine 2 di 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: passo 4, immagine 3 di 3
    • The 4 mm length screws are located on each side and on the bottom of the camera.
    • 2 screws on each side (4 total).
    • 2 screws on bottom.
  5. Sony Cyber-shot DSC-TX7 Front Cover Replacement: passo 5, immagine 1 di 1
    • Gently pry around the front cover using the plastic opening tool.
    • Carefully separate front cover from body of camera.
  6. Sony Cyber-shot DSC-TX7 Front Cover Replacement: passo 6, immagine 1 di 1
    • The front cover is now removed from the camera and the internal hardware is now visible.
    • They front cover will still be connected by a ribbon. Be careful not to break the ribbon.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 350
