Salta al contenuto principale
Sony Cyber-shot DSC-TX55 LCD Screen Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 3 Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 3 Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: passo 1, immagine 3 di 3
    • Slide open the battery cover in the direction that the arrows on device are pointing.
    • Flip the blue battery lock to eject the battery.
    • Remove the battery from the device.
  2. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Using your Phillips #00 screwdriver, remove all four 0.3 cm screws that are located on both ends, as well as the bottom of your Cyber-Shot.
    • Make sure that your screws are placed on a flat, still surface so they do not roll away.
  3. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Gently pull away the back end of the camera where the LCD screen is located.
    • Remove the metal frame that is located around the LCD screen.
  4. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Remove the front cover.
  5. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Gently remove the lens from the device.
    • The lens will hang on by the orange strips, be careful not to tug on the lens.
  6. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: passo 6, immagine 1 di 2 Sony Cyber-shot DSC-TX55 LCD Screen Replacement: passo 6, immagine 2 di 2
    • Gently slide the LCD screen using very light pressure to the right until it pops open.
  7. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: passo 7, immagine 1 di 1
    • The LCD screen will open to the right.
    • Remove the orange tab from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Megan East
Membro da: 10/13/15
555 Reputazione
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,364
