Salta al contenuto principale
Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: passo 1, immagine 1 di 3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: passo 1, immagine 2 di 3 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: passo 1, immagine 3 di 3
    • Remove the battery
    • Remove the five 2.5mm Philips #0 screws.
    • Remove the one 2.5mm Philips #0 screw inside the HDMI case.
  2. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 2, immagine 1 di 1
    • Gently work and pull the front cover off of the camera
  3. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 3, immagine 1 di 1
    • Gently pull and disconnect the ribbon cable connecting the front cover to the main body
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry off the cover of the OLED/LCD assembly.
    • Take care of the tab/clip at the bottom, it can be a little tricky.
    • iSesamo Opening Tool is highly recommended
  4. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 5, immagine 1 di 2 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 5, immagine 2 di 2
    • Remove the copper phillips screw holding the HDMI mounting plate and detach the mounting plate.
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry the OLED/LCD assembly from the adhesive strip on the main body.
    • Note: where the adhesive strip is located.
    • Turn the device over and remove the clear tape and black tape.
    • Important: Save the clear and black tape, they will be used for the replacement unit.
  5. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 7, immagine 1 di 1
    • Gently pull the small flat ribbon cable from the main body
    • In order to disconnect the large flat ribbon cable, you need to flip up the black ribbon clamp located on the main body where the socket is located
  6. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 8, immagine 1 di 1
    • Reattach new display, and reconnect all components
    • Test camera to ensure the new screen is working
    • Congrats!
Conclusione
Tim
Membro da: 03/12/12
2.127 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 4,148
