Salta al contenuto principale
Introduzione
The sliding lens cover is on the front of the camera, and moves vertically to hide or expose the lens and flash. It may need to be replaced if it becomes stuck.
Ricambi
Nessuna parte specificata.
  1. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Cover: passo 1, immagine 1 di 3 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Cover: passo 1, immagine 2 di 3 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Cover: passo 1, immagine 3 di 3
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  2. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 2, immagine 1 di 1
    • Use screwdriver to remove screws.
  3. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 3, immagine 1 di 1
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  4. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 4, immagine 1 di 1
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  5. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement, Front Sliding Lens Cover: passo 5, immagine 1 di 1
    • The front sliding lens cover.
  6. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 6, immagine 1 di 2 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 6, immagine 2 di 2
    • Remove four screws using Phillips located on the inside of the front cover.
  7. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 7, immagine 1 di 2 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 7, immagine 2 di 2
    • Remove front sliding lens cover.
  8. Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 8, immagine 1 di 2 Sony Cyber-shot DSC-T9 Front Sliding Lens Cover Replacement: passo 8, immagine 2 di 2
    • The front sliding lens cover is now removed and may be repair or replaced.
Conclusione
Stephannie Allen
Membro da: 11/03/2013
231 Reputazione
10 Guide realizzate
Clemson, Team 13-1, Benson Spring 2013 Membro di Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 16
Tutti i Tempi: 918
