Salta al contenuto principale
Sony Cyber-shot DSC-T1 Flash Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-T1 Flash Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the cover on the bottom of the camera.
    • Slide the cover towards the back of the camera.
    • Be careful—the battery can slide out on its own.
  2. Sony Cyber-shot DSC-T1 Flash Replacement: passo 2, immagine 1 di 1
    • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
  3. Sony Cyber-shot DSC-T1 Flash Replacement, Flash: passo 3, immagine 1 di 3 Sony Cyber-shot DSC-T1 Flash Replacement, Flash: passo 3, immagine 2 di 3 Sony Cyber-shot DSC-T1 Flash Replacement, Flash: passo 3, immagine 3 di 3
    • Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
  4. Sony Cyber-shot DSC-T1 Flash Replacement: passo 4, immagine 1 di 1
    • Pull the two halves of the camera apart.
    • Place the two halves down with the insides facing you.
  5. Sony Cyber-shot DSC-T1 Flash Replacement: passo 5, immagine 1 di 1
    • Find the two clips holding the motherboard to the black lens box.
    • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it. (If difficult, your fingernail can also be used)
  6. Sony Cyber-shot DSC-T1 Flash Replacement: passo 6, immagine 1 di 1
    • After releasing the clips, pull out black lens box.
  7. Sony Cyber-shot DSC-T1 Flash Replacement: passo 7, immagine 1 di 2 Sony Cyber-shot DSC-T1 Flash Replacement: passo 7, immagine 2 di 2
    • Use the plastic opening tool to flip the clip.
  8. Sony Cyber-shot DSC-T1 Flash Replacement: passo 8, immagine 1 di 2 Sony Cyber-shot DSC-T1 Flash Replacement: passo 8, immagine 2 di 2
    • Grab the white part and slide it to the right until it clicks.
    • This may require some force.
    • Pull out the flash.
Conclusione
Paul Elrich
Membro da: 04/12/12
33 Reputazione
2 Guide realizzate
Cal Poly, Team 7-35, Maness Spring 2012 Membro di Cal Poly, Team 7-35, Maness Spring 2012
CPSU-MANESS-S12S7G35
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 720
