Salta al contenuto principale
Sony Cyber-shot DSC-T1 Flash Module Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-T1 Flash Module Replacement, Battery: passo 1, immagine 1 di 2 Sony Cyber-shot DSC-T1 Flash Module Replacement, Battery: passo 1, immagine 2 di 2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Sony Cyber-shot DSC-T1 Flash Module Replacement: passo 2, immagine 1 di 1
    • Remove the battery from the door that you opened in the previous step.
  3. Sony Cyber-shot DSC-T1 Flash Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, immagine 1 di 3 Sony Cyber-shot DSC-T1 Flash Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, immagine 2 di 3 Sony Cyber-shot DSC-T1 Flash Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: passo 3, immagine 3 di 3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Sony Cyber-shot DSC-T1 Flash Module Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-T1 Flash Module Replacement: passo 4, immagine 2 di 2
    • Use hands to gently pry the front casing away from the camera.
  5. Sony Cyber-shot DSC-T1 Flash Module Replacement, CCD Sensor Module: passo 5, immagine 1 di 2 Sony Cyber-shot DSC-T1 Flash Module Replacement, CCD Sensor Module: passo 5, immagine 2 di 2
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Sony Cyber-shot DSC-T1 Flash Module Replacement: passo 6, immagine 1 di 1
    • Grasp the CCD Sensor Module and remove it.
  7. Sony Cyber-shot DSC-T1 Flash Module Replacement, Flash Module: passo 7, immagine 1 di 3 Sony Cyber-shot DSC-T1 Flash Module Replacement, Flash Module: passo 7, immagine 2 di 3 Sony Cyber-shot DSC-T1 Flash Module Replacement, Flash Module: passo 7, immagine 3 di 3
    • This camera houses a very strong capacitor (the black cylinder). Avoid touching anything around the two wires coming out of the top. Doing so will risk serious electric shock.
    • Carefully disengage the internal components from the casing by lifting at the bottom end and giving a gentle tug.
    • The components are still connected to the casing via cables, but they are much more maneuverable.
    • The flash module is shown on the right hand side.
  8. Sony Cyber-shot DSC-T1 Flash Module Replacement: passo 8, immagine 1 di 2 Sony Cyber-shot DSC-T1 Flash Module Replacement: passo 8, immagine 2 di 2
    • Use the tip of a spudger to flip up the tab on the ZIF connecter securing the motherboard ribbon cable.
    • Grasp the flash module by the bottom and remove it.
Conclusione
iDeleted
Membro da: 07/07/10
2.101 Reputazione
39 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,302
