Salta al contenuto principale
Sony Cyber-shot DSC-S2100 LCD Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: passo 1, immagine 1 di 3 Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: passo 1, immagine 2 di 3 Sony Cyber-shot DSC-S2100 LCD Replacement, LCD: passo 1, immagine 3 di 3
    • The broken LCD is immediately visible when the camera is turned on.
    • Remove the batteries and, if so equipped, the memory card.
    • Remove the three Philips screws from the bottom of the camera with a Phillips #00 Screwdriver.
  2. Sony Cyber-shot DSC-S2100 LCD Replacement: passo 2, immagine 1 di 3 Sony Cyber-shot DSC-S2100 LCD Replacement: passo 2, immagine 2 di 3 Sony Cyber-shot DSC-S2100 LCD Replacement: passo 2, immagine 3 di 3
    • Remove the two Philips screws from the right side of the camera.
    • Remove the two Philips screws from the left side of the camera.
    • Split the housing by either using a plastic opening tool, or your finger nails. No excessive force is necessary. For ease of accomplishment, start at the battery compartment.
  3. Sony Cyber-shot DSC-S2100 LCD Replacement: passo 3, immagine 1 di 3 Sony Cyber-shot DSC-S2100 LCD Replacement: passo 3, immagine 2 di 3 Sony Cyber-shot DSC-S2100 LCD Replacement: passo 3, immagine 3 di 3
    • Once the rear case has been removed, the LCD and frame are easily identified.
    • Fold the LCD to the right, away from the frame.
    • Do not try to remove the LCD yet since the ribbon cable is still connected.
    • Remove the three Philips screws from the LCD frame.
  4. Sony Cyber-shot DSC-S2100 LCD Replacement: passo 4, immagine 1 di 3 Sony Cyber-shot DSC-S2100 LCD Replacement: passo 4, immagine 2 di 3 Sony Cyber-shot DSC-S2100 LCD Replacement: passo 4, immagine 3 di 3
    • When the LCD frame is removed, the ribbon cable becomes clearly visible.
    • Flip the LCD to its left side. Open the clip of the connector by moving the black lock to the right.
    • Remove the LCD
  5. Sony Cyber-shot DSC-S2100 LCD Replacement: passo 5, immagine 1 di 1
    • Ensure the screen displayed greets you, once you reassembled your camera
Conclusione
Altre 4 persone hanno completato questa guida.
oldturkey03
Membro da: 09/29/10
781.718 Reputazione
119 Guide realizzate
Global Fixers Membro di Global Fixers
Community
32 Membri
531 Guide realizzate
2 Commenti
你在哪里?把相机给你帮我挨可以吗
Jeanne - Replica
请问你是在多伦多附近吗?
Jeanne - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 39
Tutti i Tempi: 2,455
