Parti
Nessuna parte richiesta.
Slide the battery latch down the side of the camera with your hands.
  • Slide the battery latch down the side of the camera with your hands.
  • The latch will automatically pop open.
Aggiungi Commento
Unlatch the clip over the battery.
  • Unlatch the clip over the battery.
  • The battery will partially pop out.
Aggiungi Commento
  • Remove the battery from the camera.
Aggiungi Commento
  • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
  • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
Aggiungi Commento
  • Once the screws are removed, slowly remove the back casing from the rest of the camera.
Aggiungi Commento
  • Then, pull the front case away from the rest of the camera.
Aggiungi Commento
  • After the casing is removed, the camera should look as shown.
Aggiungi Commento
Conclusione
Jenna Crawford
Membro da: 09/04/2012
29 Reputazione
3 Guide realizzate
Cal Poly, Team 17-25, Amido Spring 2012 Membro di Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 668
