Salta al contenuto principale
Sony Cyber-shot DSC-P9 Motherboard Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-P9 Motherboard Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the battery latch down the side of the camera with your hands.
    • The latch will automatically pop open.
  2. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 2, immagine 1 di 1
    • Unlatch the clip over the battery.
    • The battery will partially pop out.
  3. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 3, immagine 1 di 2 Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove the battery from the camera.
  4. Sony Cyber-shot DSC-P9 Motherboard Replacement, Outer Casing: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-P9 Motherboard Replacement, Outer Casing: passo 4, immagine 2 di 2
    • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
    • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
  5. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 5, immagine 1 di 2 Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 5, immagine 2 di 2
    • Once the screws are removed, slowly remove the back casing from the rest of the camera.
  6. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 6, immagine 1 di 2 Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 6, immagine 2 di 2
    • Then, pull the front case away from the rest of the camera.
  7. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 7, immagine 1 di 1
    • After the casing is removed, the camera should look as shown.
  8. Sony Cyber-shot DSC-P9 Motherboard Replacement, Lens: passo 8, immagine 1 di 2 Sony Cyber-shot DSC-P9 Motherboard Replacement, Lens: passo 8, immagine 2 di 2
    • Dislodge the round casing from the lens.
    • Pull it away from the rest of the camera.
  9. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 9, immagine 1 di 1
    • Unscrew the two 4.0mm Phillips #000 screws from the display.
  10. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 10, immagine 1 di 1
    • Pull the two ribbon cables out of their slots on the back circuit board.
  11. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 11, immagine 1 di 1
    • Remove the three 4.0mm Phillips #000 screws holding the back panel in place.
  12. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 12, immagine 1 di 3 Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 12, immagine 2 di 3 Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 12, immagine 3 di 3
    • Work the back panel out from under the small grey clip.
    • Slide the back panel off of the camera by dislodging it from the remaining clips.
    • Below is a flat, orange cable connecting the lens to the motherboard.
    • Be careful not to bend the back plate during this process.
  13. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 13, immagine 1 di 1
    • Turn the camera over so that you can see the front of the lens.
    • Two connectors link the lens to the motherboard.
    • Gently bring the lens away from the camera.
  14. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 14, immagine 1 di 1
    • Using the flat end of the plastic spudger tool, flip up the black tabs on the connectors.
    • Be careful not to exert too much force, as the connectors are delicate.
  15. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 15, immagine 1 di 3 Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 15, immagine 2 di 3 Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 15, immagine 3 di 3
    • Gently pull out the cables and move the lens away from the rest of the camera.
    • You should now have two distinct, separate components.
  16. Sony Cyber-shot DSC-P9 Motherboard Replacement, Motherboard: passo 16, immagine 1 di 2 Sony Cyber-shot DSC-P9 Motherboard Replacement, Motherboard: passo 16, immagine 2 di 2
    • Rotate the bottom panel upwards and pull away with your hand.
  17. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 17, immagine 1 di 1
    • Remove the one 2.5mm Phillips #000 screw on the bottom corner of the motherboard.
  18. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 18, immagine 1 di 1
    • Lift the black tab holding the top-left ribbon cable in place with the spudger tool.
    • Remove the ribbon cable with the spudger by carefully pulling the cable directly out of the slot.
    • Take care not to rip the ribbon cable when pulling it out.
  19. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 19, immagine 1 di 1
    • Lift the black tab that locks the orange ribbon cable in place.
    • Remove the ribbon cable by gently pulling it out of the slot with the spudger.
    • Take care not to rip the ribbon cable when pulling it out, and be mindful of a second cable beneath the first.
  20. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 20, immagine 1 di 2 Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 20, immagine 2 di 2
    • Remove the second ribbon cable below the first one by gently pulling it out of the slot with the spudger.
  21. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 21, immagine 1 di 2 Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 21, immagine 2 di 2
    • Remove the ribbon cable to the right of the bottom two ribbon cables with the spudger.
  22. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 22, immagine 1 di 2 Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 22, immagine 2 di 2
    • Pull the motherboard out of the slot on the side of the camera where the lens used to be attached.
  23. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 23, immagine 1 di 3 Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 23, immagine 2 di 3 Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 23, immagine 3 di 3
    • Lift the motherboard away from the camera.
    • Detach the final ribbon cable connecting the motherboard to the rest of the camera.
  24. Sony Cyber-shot DSC-P9 Motherboard Replacement: passo 24, immagine 1 di 1
    • The motherboard should now be fully disconnected from the rest of the camera.
Conclusione
Cal Poly, Team 17-25, Amido Spring 2012 Membro di Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,232
