Parti
Nessuna parte richiesta.
Slide the battery latch down the side of the camera with your hands.
  • Slide the battery latch down the side of the camera with your hands.
  • The latch will automatically pop open.
Aggiungi Commento
Unlatch the clip over the battery.
  • Unlatch the clip over the battery.
  • The battery will partially pop out.
Aggiungi Commento
  • Remove the battery from the camera.
Aggiungi Commento
  • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
  • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
Aggiungi Commento
  • Once the screws are removed, slowly remove the back casing from the rest of the camera.
Aggiungi Commento
  • Then, pull the front case away from the rest of the camera.
Aggiungi Commento
  • After the casing is removed, the camera should look as shown.
Aggiungi Commento
  • Dislodge the round casing from the lens.
  • Pull it away from the rest of the camera.
Aggiungi Commento
  • Unscrew the two 4.0mm Phillips #000 screws from the display.
Aggiungi Commento
  • Pull the two ribbon cables out of their slots on the back circuit board.
Aggiungi Commento
  • Remove the three 4.0mm Phillips #000 screws holding the back panel in place.
Aggiungi Commento
  • Work the back panel out from under the small grey clip.
  • Slide the back panel off of the camera by dislodging it from the remaining clips.
  • Below is a flat, orange cable connecting the lens to the motherboard.
  • Be careful not to bend the back plate during this process.
Aggiungi Commento
  • Turn the camera over so that you can see the front of the lens.
  • Two connectors link the lens to the motherboard.
  • Gently bring the lens away from the camera.
Aggiungi Commento
  • Using the flat end of the plastic spudger tool, flip up the black tabs on the connectors.
  • Be careful not to exert too much force, as the connectors are delicate.
Aggiungi Commento
  • Gently pull out the cables and move the lens away from the rest of the camera.
  • You should now have two distinct, separate components.
Aggiungi Commento
  • Rotate the bottom panel upwards and pull away with your hand.
Aggiungi Commento
  • Remove the one 2.5mm Phillips #000 screw on the bottom corner of the motherboard.
Aggiungi Commento
  • Lift the black tab holding the top-left ribbon cable in place with the spudger tool.
  • Remove the ribbon cable with the spudger by carefully pulling the cable directly out of the slot.
  • Take care not to rip the ribbon cable when pulling it out.
Aggiungi Commento
  • Lift the black tab that locks the orange ribbon cable in place.
  • Remove the ribbon cable by gently pulling it out of the slot with the spudger.
  • Take care not to rip the ribbon cable when pulling it out, and be mindful of a second cable beneath the first.
Aggiungi Commento
  • Remove the second ribbon cable below the first one by gently pulling it out of the slot with the spudger.
Aggiungi Commento
  • Remove the ribbon cable to the right of the bottom two ribbon cables with the spudger.
Aggiungi Commento
  • Pull the motherboard out of the slot on the side of the camera where the lens used to be attached.
Aggiungi Commento
  • Lift the motherboard away from the camera.
  • Detach the final ribbon cable connecting the motherboard to the rest of the camera.
Aggiungi Commento
  • The motherboard should now be fully disconnected from the rest of the camera.
Aggiungi Commento
Conclusione
Robert Potter
Membro da: 10/04/2012
35 Reputazione
1 Guida realizzata
Cal Poly, Team 17-25, Amido Spring 2012 Membro di Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 935
