Introduzione
The camera will need to be completely disassembled to get to the flash, so only do this as as a last resort.
Open the battery compartment and remove the batteries.
  • Open the battery compartment and remove the batteries.
  • Remove all of the visible screws on the outside of the case.
  • There should be three of them that are all easily located.
Aggiungi Commento
Open the memory card compartment.
  • Open the memory card compartment.
  • Remove the screw next to the memory card slot.
Aggiungi Commento
  • Pull apart the front and back cover pieces carefully.
  • The front cover should come completely free with little effort.
  • The back cover will still be attached to the circuit board.
Aggiungi Commento
  • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
  • The circuitry will still be connected to the back case by ribbon cables.
Aggiungi Commento
  • Open the case as shown.
Aggiungi Commento
  • Unclip the clip holding the ribbon cable in.
  • Other ribbon cables might not have a clips.
Aggiungi Commento
  • Pull the ribbon cable out.
Aggiungi Commento
  • Remove all six screws on the front side of the motherboard circled in the picture.
  • Pull the motherboard from the rest of the housing.
  • It will still be connected to the flash unit.
Aggiungi Commento
  • Remove the cable on the back side of the motherboard.
Aggiungi Commento
  • Detach the ribbon cables shown.
  • Careful! Touching the leads of the large yellow capacitor can result in a painful shock.
  • Remove the flash unit from the motherboard.
Aggiungi Commento
  • Discharge the yellow capacitor attached to the flash unit by shorting the leads with a screw driver.
  • Avoid touching the leads with your hands, as this can result in a painful shock.
Discharge the yellow capacitor attached to the flash unit by shorting the leads with a screw driver having a non-conductive handle.
Stephen Daugherty - Replica
  • Replace the flash unit.
Aggiungi Commento
Conclusione
Trevor
Membro da: 20/01/2011
277 Reputazione
6 Guide realizzate
Cal Poly, Team 3-43, Regan Winter 2011 Membro di Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,600
