Salta al contenuto principale
Sony Cyber-shot DSC-P100 Camera Flash Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: passo 1, immagine 1 di 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: passo 1, immagine 2 di 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement, Front Casing: passo 1, immagine 3 di 3
    • First locate the appropriate screws for detachment.
  2. Sony Cyber-shot DSC-P100 Camera Flash Replacement: passo 2, immagine 1 di 1
    • Remove the five screws shown using a Phillips #00 Screwdriver.
    • It is important to put the small screws in a safe location in order to reassemble the casing.
  3. Sony Cyber-shot DSC-P100 Camera Flash Replacement: passo 3, immagine 1 di 1
    • Using a spudger, carefully pry open the front casing.
  4. Sony Cyber-shot DSC-P100 Camera Flash Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-P100 Camera Flash Replacement: passo 4, immagine 2 di 2
    • Carefully separate the front casing from the camera body.
    • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
  5. Sony Cyber-shot DSC-P100 Camera Flash Replacement, Camera Flash: passo 5, immagine 1 di 2 Sony Cyber-shot DSC-P100 Camera Flash Replacement, Camera Flash: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, gently pull the ribbon trace out of its housing found on the left side of the flash.
  6. Sony Cyber-shot DSC-P100 Camera Flash Replacement: passo 6, immagine 1 di 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement: passo 6, immagine 2 di 3 Sony Cyber-shot DSC-P100 Camera Flash Replacement: passo 6, immagine 3 di 3
    • Using a spudger, pry the small latch between the lens and the flash open to release the flash.
    • Pull the flash away from the camera.
Conclusione
Katie McCraw
Membro da: 03/09/12
191 Reputazione
7 Guide realizzate
Clemson, Team 1-5, Benson Spring 2012 Membro di Clemson, Team 1-5, Benson Spring 2012
CLEM-BENSON-S12S1G5
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 2,572
