Salta al contenuto principale
Sony Cyber-shot DSC-HX90V Button Board Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: passo 1, immagine 1 di 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: passo 1, immagine 2 di 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement, Button Board: passo 1, immagine 3 di 3
    • Remove the marked screw with a Phillips #000 screwdriver.
    • Remove the marked black M1.4 X 3.5 Phillips head screws
    • Use the spudger to gently remove the lower panel.
  2. Sony Cyber-shot DSC-HX90V Button Board  Replacement: passo 2, immagine 1 di 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: passo 2, immagine 2 di 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: passo 2, immagine 3 di 3
    • After removing the marked black M1.4 X 3.5 Phillips head screws with the Phillips #000 screwdriver on the side panel, using the spudger where the red arrow marks, insert and gently remove the side panel from the device.
    • From either corner of the button board gently use hands to remove the button board.
  3. Sony Cyber-shot DSC-HX90V Button Board  Replacement: passo 3, immagine 1 di 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: passo 3, immagine 2 di 3 Sony Cyber-shot DSC-HX90V Button Board  Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • After the outer black panel case of button is removed, gently disconnect the control board data cable to the motherboard utilizing the tweezers gently where the red arrow marks.
    • Ribbon wires can easily be damaged.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 27
Tutti i Tempi: 2,010
