Salta al contenuto principale
Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the camera is powered off
    • Turn the camera upside down. This is a view of the bottom of the camera.
  2. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 2, immagine 1 di 1
    • Push battery cover away from the camera.
  3. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 3, immagine 1 di 1
    • Push the blue tab that secures the battery. The battery will then spring out.
  4. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 4, immagine 2 di 2
    • Remove the battery.
  5. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: passo 5, immagine 1 di 3 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: passo 5, immagine 2 di 3 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, Motherboard: passo 5, immagine 3 di 3
    • Make sure to remove the battery before disassembly to prevent electrocution.
    • Remove the 3 (4 cm) Phillips head screws located on the back of the camera.
    • Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
    • Turn the camera upside down to remove the remaining the 3 (4 cm) Phillips head screws holding the plastic camera housing together.
  6. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 6, immagine 1 di 2 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 6, immagine 2 di 2
    • Using a plastic opening tool, separate the plastic camera housing.
  7. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 7, immagine 1 di 1
    • Disconnect the ribbon wire attaching the screen to the camera.
  8. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 8, immagine 1 di 3 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 8, immagine 2 di 3 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 8, immagine 3 di 3
    • Carefully remove the 7 ribbon wires connected to the mother board.
    • Remove the 2 (5 cm) Phillips head screws on the speaker mounting bracket.
    • Remove the 3 (4 cm) Phillips head screws that secure the motherboard to the camera.
    • Lift up on the speaker mounting bracket to remove it.
  9. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 9, immagine 1 di 2 Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 9, immagine 2 di 2
    • Carefully disconnect the ribbon wire connecting the HDMI port to the Motherboard.
    • Once the Motherboard is removed the replacement can be installed.
  10. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement, HDMI/USB port: passo 10, immagine 1 di 1
    • Remove the 3 (4 cm) Phillips head screws securing a mounting bracket over the HDMI/USB Port.
  11. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 11, immagine 1 di 1
    • Lift up on the mounting bracket to remove the HDMI/USB Port from the camera.
  12. Sony Cyber-shot DSC-HX300 HDMI/USB port Replacement: passo 12, immagine 1 di 1
    • Once the HDMI/USB Port is removed the replacement can be installed.
Conclusione
USF Tampa, Team 4-6, Meier Fall 2015 Membro di USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,301
