Salta al contenuto principale
Sony Cyber-shot DSC-HX100V Viewfinder Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-HX100V Viewfinder Replacement, Viewfinder: passo 1, immagine 1 di 1
    • Make sure camera is turned off.
    • Press the ON/Off button to turn off the camera.
    • WARNING: Data may be lost if the camera remains on.
  2. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 2, immagine 1 di 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 2, immagine 2 di 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 2, immagine 3 di 3
    • Use the Phillips screwdriver size #00 to remove the 1.59mm #00 screws.
    • Remove 2 screws from the side of the camera.
    • Remove 4 screws on the bottom of the camera.
    • Remove 1 screw next to the eyepiece.
  3. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 3, immagine 1 di 1
    • Flip the screen back to reveal 2 hidden screws.
    • Remove the two 1.59mm #00 screws on the left with the Phillips #00 screwdriver.
  4. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 4, immagine 1 di 1
    • Pull the back panel of the camera upward.
    • Use a spudger to help pry open the back panel.
  5. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 5, immagine 1 di 1
    • Open the back panel to view the inside of the camera.
    • If the orange ribbon cable disconnects from its designated port, do not panic. The cable is easy to reinsert.
  6. Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 6, immagine 1 di 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 6, immagine 2 di 3 Sony Cyber-shot DSC-HX100V Viewfinder Replacement: passo 6, immagine 3 di 3
    • Carefully pull out the the eyepiece.
    • Detach the orange ribbon cable that connects it to the green panel by carefully pulling outwards.
Conclusione
Un commento
Thank you very much for the importent articles made for us. If I can please put , how to replace the flasher as well.
Satsara Gunaratne - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 918
