Salta al contenuto principale
Sony Cyber-shot DSC-HX1 Button Assembly Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-HX1 Button Assembly Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
  2. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: passo 2, immagine 1 di 1
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
  3. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: passo 3, immagine 1 di 2 Sony Cyber-shot DSC-HX1 Button Assembly Replacement: passo 3, immagine 2 di 2
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
  4. Sony Cyber-shot DSC-HX1 Button Assembly Replacement, Button Assembly: passo 4, immagine 1 di 1
    • On the top of the inside the battery compartment, remove the #00 6.0 mm Phillips screw.
  5. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: passo 5, immagine 1 di 2 Sony Cyber-shot DSC-HX1 Button Assembly Replacement: passo 5, immagine 2 di 2
    • Lift the button housing from its position on top of the camera.
Conclusione
Cal Poly, Team 17-3, Forte Spring 2015 Membro di Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 14
Tutti i Tempi: 854
