Salta al contenuto principale
Sony Cyber-shot DSC-H200 SD Door Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: passo 1, immagine 1 di 2 Sony Cyber-shot DSC-H200 SD Door Replacement, SD Door: passo 1, immagine 2 di 2
    • Using a screwdriver, remove four 6mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 2, immagine 1 di 1
    • Using a screwdriver, remove the two 6mm screws on the bottom.
    • Using a screwdriver, remove the four 3mm screws on the bottom.
  3. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 3, immagine 1 di 1
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-H200 SD Door Replacement: passo 4, immagine 2 di 2
    • Using the blue plastic opening tools, remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 5, immagine 1 di 2 Sony Cyber-shot DSC-H200 SD Door Replacement: passo 5, immagine 2 di 2
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable).
    • Using the blue plastic opening tool remove the LCD Screen from the motherboard.
  6. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 6, immagine 1 di 1
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 7, immagine 1 di 1
    • Lift the holding plate away from the motherboard and set aside (the pin attaching the door to the body is now accessible).
  8. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 8, immagine 1 di 2 Sony Cyber-shot DSC-H200 SD Door Replacement: passo 8, immagine 2 di 2
    • Using tweezers remove the pin that attaches the door to the body.
  9. Sony Cyber-shot DSC-H200 SD Door Replacement: passo 9, immagine 1 di 1
    • Remove the door.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,552
