Salta al contenuto principale
Sony Cyber-shot DSC-H200 Motherboard Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-H200 Motherboard Replacement, LCD Screen: passo 1, immagine 1 di 3 Sony Cyber-shot DSC-H200 Motherboard Replacement, LCD Screen: passo 1, immagine 2 di 3 Sony Cyber-shot DSC-H200 Motherboard Replacement, LCD Screen: passo 1, immagine 3 di 3
    • Using a screwdriver, remove the five 6mm screws located on the back panel.
    • Using a screwdriver, remove the two 3mm screws located on the back panel.
  2. Sony Cyber-shot DSC-H200 Motherboard Replacement: passo 2, immagine 1 di 1
    • Using a screwdriver, remove one 6mm screw on the front panel.
    • Using a screwdriver, remove two 3mm screws on the front panel.
  3. Sony Cyber-shot DSC-H200 Motherboard Replacement: passo 3, immagine 1 di 1
    • Open the SD Door, unscrew and remove the single 6mm screw closest to "PUSH IN/OUT" under the SD card slot.
  4. Sony Cyber-shot DSC-H200 Motherboard Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-H200 Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the back panel (the LCD and motherboard are exposed).
  5. Sony Cyber-shot DSC-H200 Motherboard Replacement: passo 5, immagine 1 di 1
    • Using a screwdriver, remove the three 4mm screws that attach the LCD to the camera motherboard. (The LCD is contained in a holding plate, attached to the motherboard with a ribbon cable.)
  6. Sony Cyber-shot DSC-H200 Motherboard Replacement: passo 6, immagine 1 di 1
    • Using a screwdriver, remove the single 4mm screw at the bottom of the holding plate.
  7. Sony Cyber-shot DSC-H200 Motherboard Replacement: passo 7, immagine 1 di 2 Sony Cyber-shot DSC-H200 Motherboard Replacement: passo 7, immagine 2 di 2
    • Lift the holding plate away from the motherboard and set aside.
  8. Sony Cyber-shot DSC-H200 Motherboard Replacement: passo 8, immagine 1 di 1
    • Using tweezers, open the LCD ribbon port by lifting the black hinge. (The LCD ribbon cable will detach.)
  9. Sony Cyber-shot DSC-H200 Motherboard Replacement: passo 9, immagine 1 di 3 Sony Cyber-shot DSC-H200 Motherboard Replacement: passo 9, immagine 2 di 3 Sony Cyber-shot DSC-H200 Motherboard Replacement: passo 9, immagine 3 di 3
    • Using tweezers, remove the LCD with the ribbon cable and set aside.
  10. Sony Cyber-shot DSC-H200 Motherboard Replacement, Motherboard: passo 10, immagine 1 di 1
    • Disconnect the four amber-colored ribbon cables from the motherboard using tweezers.
  11. Sony Cyber-shot DSC-H200 Motherboard Replacement: passo 11, immagine 1 di 1
    • Disconnect all wires from the motherboard by using a soldering iron.
    • Users unfamiliar with a soldering iron should be extremely careful as the device can get very hot.
  12. Sony Cyber-shot DSC-H200 Motherboard Replacement: passo 12, immagine 1 di 1
    • Gently lift the motherboard away from the camera body.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 2,780
