Salta al contenuto principale
Sony Cyber-shot DSC-H20 Screen Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-H20 Screen Replacement, Screen: passo 1, immagine 1 di 2 Sony Cyber-shot DSC-H20 Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Screen Replacement: passo 2, immagine 1 di 1
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Screen Replacement: passo 3, immagine 1 di 2 Sony Cyber-shot DSC-H20 Screen Replacement: passo 3, immagine 2 di 2
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Screen Replacement: passo 4, immagine 1 di 3 Sony Cyber-shot DSC-H20 Screen Replacement: passo 4, immagine 2 di 3 Sony Cyber-shot DSC-H20 Screen Replacement: passo 4, immagine 3 di 3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Screen Replacement: passo 5, immagine 1 di 1
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  6. Sony Cyber-shot DSC-H20 Screen Replacement: passo 6, immagine 1 di 3 Sony Cyber-shot DSC-H20 Screen Replacement: passo 6, immagine 2 di 3 Sony Cyber-shot DSC-H20 Screen Replacement: passo 6, immagine 3 di 3
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Screen Replacement: passo 7, immagine 1 di 1
    • Remove the power shutter unit.
  8. Sony Cyber-shot DSC-H20 Screen Replacement: passo 8, immagine 1 di 2 Sony Cyber-shot DSC-H20 Screen Replacement: passo 8, immagine 2 di 2
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
  9. Sony Cyber-shot DSC-H20 Screen Replacement: passo 9, immagine 1 di 1
    • Remove the two screws from the bottom of the motherboard.
  10. Sony Cyber-shot DSC-H20 Screen Replacement: passo 10, immagine 1 di 1
    • Use the plastic opening tool to assist you in separating the metal frame from the back cover of the camera.
  11. Sony Cyber-shot DSC-H20 Screen Replacement: passo 11, immagine 1 di 2 Sony Cyber-shot DSC-H20 Screen Replacement: passo 11, immagine 2 di 2
    • Flip the metal frame over to the left side of the camera and onto the surface on which you are working.
  12. Sony Cyber-shot DSC-H20 Screen Replacement: passo 12, immagine 1 di 2 Sony Cyber-shot DSC-H20 Screen Replacement: passo 12, immagine 2 di 2
    • Now remove the LCD screen by bringing the back cover over to the left so that the LCD screen falls into your hand.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 1-1, Leahy Winter 2015 Membro di USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
3 Membri
10 Guide realizzate
Un commento
Thank you so much. I could successfully open the camera and got the LCD display out. But I couldn't find out how to replace the LCD, I wanted to mean where to open the LCD cable?
ummejamil - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,952
