Salta al contenuto principale
Sony Cyber-shot DSC-H20 Lens Assembly Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-H20 Lens Assembly Replacement, Lens Assembly: passo 1, immagine 1 di 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement, Lens Assembly: passo 1, immagine 2 di 2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 2, immagine 1 di 1
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 3, immagine 1 di 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 3, immagine 2 di 2
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 4, immagine 1 di 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 4, immagine 2 di 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 4, immagine 3 di 3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 5, immagine 1 di 1
    • Place the camera upside down with the battery port positioned upward and the battery port open.
  6. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 6, immagine 1 di 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 6, immagine 2 di 3 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 6, immagine 3 di 3
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 7, immagine 1 di 1
    • Remove the power shutter unit
  8. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 8, immagine 1 di 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 8, immagine 2 di 2
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
  9. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 9, immagine 1 di 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 9, immagine 2 di 2
    • Lift up the gray plastic facing in order to uncover the motherboard and the ribbon cable ports.
  10. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 10, immagine 1 di 2 Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 10, immagine 2 di 2
    • Carefully flip up the three black clasps holding the lens cables to the motherboard.
    • Slide the cables from the ports.
  11. Sony Cyber-shot DSC-H20 Lens Assembly Replacement: passo 11, immagine 1 di 1
    • Lift the lens and attached ribbon cables from the camera in order to switch this lens with a new one.
Conclusione
USF Tampa, Team 1-1, Leahy Winter 2015 Membro di USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 39
Tutti i Tempi: 2,674
