Salta al contenuto principale
Ricambi
Nessuna parte specificata.
  1. Sony Cyber-shot DSC-H20 Flash Assembly Replacement, Flash Assembly: passo 1, immagine 1 di 2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement, Flash Assembly: passo 1, immagine 2 di 2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: passo 2, immagine 1 di 1
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: passo 3, immagine 1 di 2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: passo 3, immagine 2 di 2
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: passo 4, immagine 1 di 3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: passo 4, immagine 2 di 3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: passo 4, immagine 3 di 3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: passo 5, immagine 1 di 2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: passo 5, immagine 2 di 2
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  6. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: passo 6, immagine 1 di 3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: passo 6, immagine 2 di 3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: passo 6, immagine 3 di 3
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: passo 7, immagine 1 di 1
    • Remove the power shutter unit
  8. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: passo 8, immagine 1 di 2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: passo 8, immagine 2 di 2
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
Conclusione
USF Tampa, Team 1-1, Leahy Winter 2015 Membro di USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
3 Membri
10 Guide realizzate
Un commento
how to bye power sutter unit
aloke mondal - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,128
