Salta al contenuto principale
Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement
Cosa ti serve
  1. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: passo 1, immagine 1 di 3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: passo 1, immagine 2 di 3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement, Micro-USB Port: passo 1, immagine 3 di 3
    • Remove the battery before beginning.
    • Remove the three screws from the side of the lens using a JIS #000 screwdriver.
    • Remove the longer single screw from the bottom of the lens using a JIS #000 screwdriver.
  2. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: passo 2, immagine 1 di 2 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: passo 2, immagine 2 di 2
    • Remove the housing over the lens circuit board.
    • When removing the housing from over the circuit board, be cautious of static when touching the circuit board as to not fry any necessary components.
  3. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: passo 3, immagine 1 di 1
    • Unplug the micro-USB type B port from the main circuit board in the lens.
    • When handling the flex cable, be careful as to not destroy this delicate part and cause damage to other components.
  4. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: passo 4, immagine 1 di 2 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: passo 4, immagine 2 di 2
    • Set the camera aside.
    • Remove the two JIS #000 screws connecting the micro-USB type B port to the housing frame.
  5. Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: passo 5, immagine 1 di 3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: passo 5, immagine 2 di 3 Sony Cyber-shot DSC-F717 Lens Micro-USB Port Type B Replacement: passo 5, immagine 3 di 3
    • Remove the damaged micro-USB type B port by lightly pulling near the cable connector.
    • Remove the micro-USB port from the case and replace it with a new micro-USB type B port.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 37
Tutti i Tempi: 894
