Salta al contenuto principale
Sony Cyber-Shot DSC-W120 Lens Assembly Replacement
Cosa ti serve
  1. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement, Lens Assembly: passo 1, immagine 1 di 1
    • Unscrew the screws on the right side of the camera.
  2. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 2, immagine 1 di 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 2, immagine 2 di 2
    • Using a plastic opening tool, gently lift the side of the silver piece on the right side of the camera until it can be removed.
  3. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 3, immagine 1 di 3 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 3, immagine 2 di 3 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 3, immagine 3 di 3
    • Use a plastic opening tool to separate the front case of the camera, and gently remove it.
  4. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 4, immagine 1 di 1
    • Use a plastic opening tool to remove the silver piece on the left side of the camera.
  5. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 5, immagine 1 di 1
    • Remove the three screws from the bottom of the camera.
  6. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 6, immagine 1 di 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 6, immagine 2 di 2
    • Carefully remove the back case with a plastic opening tool.
  7. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 7, immagine 1 di 1
    • Unscrew the screw just above the mode dial.
  8. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Lift the display from the rest of the camera and gently separate the connecting tape using tweezers.
  9. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 9, immagine 1 di 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 9, immagine 2 di 2
    • Separate the tape connecting the lens to the rest of the camera using tweezers.
    • Remove the lens.
  10. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 10, immagine 1 di 2 Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 10, immagine 2 di 2
    • Insert wisdom here.
  11. Sony Cyber-Shot DSC-W120 Lens Assembly Replacement: passo 11, immagine 1 di 1
Conclusione
Altre 2 persone hanno completato questa guida.
Dana Sanchez
Membro da: 10/21/14
69 Reputazione
3 Guide realizzate
USF Tampa, Team 1-5, Leahy Fall 2014 Membro di USF Tampa, Team 1-5, Leahy Fall 2014
USFT-LEAHY-F14S1G5
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 56
Tutti i Tempi: 2,104
