Salta al contenuto principale
Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement
Cosa ti serve
  1. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Battery: passo 1, immagine 1 di 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Battery: passo 1, immagine 2 di 2
    • Using your finger, slide the release catch to unlock the battery/memory card cover.
  2. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 2, immagine 1 di 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 2, immagine 2 di 2
    • Open the battery/memory card door.
  3. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 3, immagine 1 di 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 3, immagine 2 di 2
    • Push the battery eject lever to free the battery.
  4. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the device.
  5. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Outer Shell: passo 5, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove one black 2 2/5mm screw that is located next to the wrist band loop.
  6. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 6, immagine 1 di 1
    • Using the plastic opening tool, separate the edge-casing from the rest of the camera.
  7. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 7, immagine 1 di 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 7, immagine 2 di 2
    • Pull the edge-casing off of the camera.
  8. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 8, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove one silver 3mm screw located on the front side of the camera.
    • Using a Phillips #00 screwdriver, remove one silver 5 2/5mm screw located on the front side of the camera
    • Using a Phillips #00 screwdriver, remove one black 2 1/2mm screw located on the front side of the camera.
  9. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 9, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove one 2 1/2mm screw located near the wrist strap.
  10. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 10, immagine 1 di 1
    • Using a Phillips #00 screwdriver remove one black 2 2/5mm screw near the tripod slot on the bottom of the casing.
  11. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 11, immagine 1 di 1
    • Using a Phillips #00 screwdriver remove the two 2 2/5mm black screws from the side of the camera opposite of the wrist strap
  12. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 12, immagine 1 di 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 12, immagine 2 di 2
    • Using the plastic opening tool, open the device's outer shell.
  13. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 13, immagine 1 di 2 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 13, immagine 2 di 2
    • Remove the front casing of the device.
  14. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Back Casing: passo 14, immagine 1 di 3 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Back Casing: passo 14, immagine 2 di 3 Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Back Casing: passo 14, immagine 3 di 3
    • Using the plastic opening tool, remove the back casing of the device.
  15. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement, Wrist Strap Holster: passo 15, immagine 1 di 1
    • Using a Phillips #00 screwdriver , remove two silver 3mm screws from the side of the device.
  16. Sony Cyber-Shot DSC-TX30 Wrist Strap Holster Replacement: passo 16, immagine 1 di 1
    • Using your fingers, remove the silver wrist band holster from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 450
